getlower
i have recently purchaced a gtir had it about 2 weeks very impressed. i was giving it the once over yesterday. and found that the air flow plug had been cut of and replaced with individual termanals. so i was just making sure they were tight on there and they sparked and the car cut out. it wouldnt start again so i checked the fuses and found that the engine comp fuse had gone in the fuse box near the inner wing on the passenger side. so i replaced this but the car still will not start. i dont have any fuel coming up and i dnt have a spark. just wondering if any1 had any ideas? any other locations of fuse boxs ect? were is the ecu located? does the ecu have a fuse? do you think i could have blown the ecu? i have put a live feed to the fuel pump and everything is ok there. any info would be much appershated thanx:roll:
