HELP!!! gti-r bogs
92_senatRa
Ok so this past weekend i was washing the car and after finishing went to start it and started up but died, so i thought maybe the plugs got wet through the hood scoop. check the plugs all good. after further troubleshooting found out my fuel pump took a dump. got an used pump from a R32 GT-R (same as Z32) and the car now starts but idles fine for 5 secs and then dies, if i give it gas it will stay running but wants to die My dizzy cap looked kinda weird, the #1 and 3 contacts were worn almost to the plastic, tried swapping with a slightly better one a a friend had laying around but no help. all the fuel lines were put back in the same place, even put a new fuel filter. new plugs and still the same. Do I need an adj. FPR if for this pump? i havent checked fuel press yet.
BTW is a 92 pulsar gti-r and scew nissan japan! you would think the damn parts will be cheaper here but hell no its hella expensive!!!
__________________
Dangerous Dave
Whats the spec of the car mate?
what fuel pump did it have in before? was it a standard one?
Are you sure you put the line's back on right?
Can you hear the fuel pump prime up?
92_senatRa
i had the standard pump before, and yes, i can hear it prime(quite loud)
the specs are pretty much std. except boost controller and uprated chipped ecu
