Kingy69
This is the story so far.Went to Mexico in september and got K.O by a jet ski at 55mph so have not been able to use my car until now due to injuries.
Car was smoking a little before i went but when i came back it started but wouldnt idle.It more or less shook itself to pieces,idle was 450rpm.Smoke bellowed from the exhaust.When i stripped it down...with my one good hand the turbo was loose as the nuts had worked there way off.I decided to get the turbo checked and it was half dead so bought a new super hybrid T28,same as previously fitted.Ive fitted this,not easy i can tell you with one hand.Primed the turbo like you do and started the car and it still wont idle.
Fault check shows the AFM code.I take it this is the module just after the filter with the two tiny sensors to check flow.This was clean but dont know what other checks can be done.
Ive got a Apexi safc fitted and if i change the pressure sensor to 1 in 3 out it idles at 1300rpm previously it was 996rpm.Dont really know what im doing when it comes down to this unit but it was set at 1 in 1 out so by altering is this just compensating for the fault as it still doesnt seem to run properly.There is white smoke from the exhaust but this is water not oil.probably just condensation build up.
Any help would be greatful as i live near peterborough and no one round here will touch the car and it doesnt really run well enough to get it anywhere for repair so im screwed.
