a few years ago ('02 iirc) ivan tomic (oz) discovered and posted how the power transistor overheating could cause loss of power (and even a flat spot in the rev range)
[experienced in both the 'R and a normal N14]
cleaning off the old factory heatsink compound and re-applying new stuff overcame the issue
(and as confirmation, several other members having power-loss issues after driving for 20 mins or so also found this was the solution to their problems)
but as has been suggested above - the bracket that the transistor is mounted to is indeed connected to the engine, which itself gets rather warm
(but you'd assume the transistor must get hotter than the bracket - otherwise the paste would have no effect)
so some owners have removed the transistor and mounted it on its own heat sink - away from the block:
