Hi Guys,
Just putting my head back on and think i may have dropped a bollock.....:doh:
Had the head skimmed and the company had to take what i think is a location spring tension pin out of the head before skimming (its about 12 mm dia and about the same in length. I have just put the head back on with a new gasket and placed the head bolts in loosely, however i have just found this bloody dowel pin on my bench........doooo. will it have any detroment not fitting this or should i take the head back off as i havent torqued it up yet?
Also, looking at the online manual, it appears to suggest that liquid gasket should be applied to the head before fitting the gasket (around the timing chain end of the block)?? any thoughts guys as I intended to put on totally dry.
cheers,
Lee
cheers,
Lee
