Head Gasket
Bosso
I'm struggling to find an uprated head gasket with 86mm bore to my engine. where do i fin one? I'm going to use 86 mm pistons, i need 86 mm gasket as well? just so i don't get the wrong one.
rx jamie
yeah its worth spending a bit on the headgasket. looking back in hindsight i wish i had, i have a cometic. no problems so far tho and after a good seasons racing.
try www.rhdjapan.com
rx jamie
your headgasket bore should obviously be a slightly larger bore than your pistons.
yeah not had a problem with mine and i only drive it on the strip. i run 1.2 bar on a gt2871r moving up to 2 bar in the new year. so we'll see then lol
:lol::lol::lol: sorry guys but this thread is funny as fcuk:lol:
got a norwegian and italian both trying their best to speak english
fair play to you both bosso and tenfold:lol::thumbsup:
stumo
and they still do a better job than all the retards on here:doh:
Bosso
What thickness should i have? I got stock internals with new pistons. The pistons i buy will have the compretion ratio 8:5:1
Trondelond
If you're struggling with the head gasket, I suppose the friendly people at nengun will be able to help you out :
http://www.nengun.com/tomei/head-gasket-metal-super-grommet-nissan-sr20det
http://www.nengun.com/tomei/head-gasket-steel-nissan-sr20det
http://www.nengun.com/power-enterprise/head-gasket
Or, you could try Eric's Performance Parts on eBay. http://stores.ebay.com/Erics-Performance-Parts
Bosso : Og ikke hør på PULSARBOBY(!), jeg har til og med korrigert stavinga hans ved anledning. :p
:lol::lol:what you dont know trond is that i speak fluent norwegian
and this is my reply but dont tell anyone else what were talking about;-)
der ikke noe galt med meg staver Trond, på gjensyn aldri realiserbar det jeg kunne snakke norsk did du:lol:. mesteren og tenfoloten er meget morsom skjønt bortsett fra de er gjør nå vel og jeg formodning i motsetning til meg , uten behovet av en oversette:thumbsup:
Trondelond
Holy crap, I just about rolled off the chair lauging at that! Ok, I see your point now, it must be a hilarious thread to read! I can't even begin to translate what you wrote into something meaningful! :D
as del boy would say from only fools & horses 'you know it makes sense':lol::lol:
anyway back to bosso's question, if you want to keep a standard compression ratio then fit a 1.2mm gasket with your 8.5:1 pistons.
i would say your best off using an hks gasket which can be sourced from graham goode racing (you wont get cheaper) just tell them the piston diamater and they will give you the appropiate sized gasket.
if however you want to drop the compression ratio to run higher boost levels more safely then go for a 2mm gasket thickness, but this will make engine more laggy off boost.
Trondelond
What are "higher boost levels" in your opinion?
If going for a bigger turbo, even less response off boost would make it pretty annoying as a daily driver.
