On the weekend i changed my intercooler from a front mount back to a top mount, with the help of Del and Mika. Everything went smoothly, with the exception of a flat battery from having the stereo on.
When starting the car, especially after putting in the tmic, it turns over many times before it fires, and then it will stumble for several seconds and sometimes stall before it comes good. Once it is running i have no problems, idles and drives perfectly, it is only when starting it. It varies on the severity of the problem, sometimes it takes a few goes to start it, and then sometimes it will start first pop. When it is hot it seems to be a little worse.
I have had this problem since i bought the car 4 months ago, but never as bad as it is at the moment. However the problem did dissapear before when i was using premium unleaded, i am using Optimax at the moment. I also have a surge tank and an uprated fuel pump.
I have checked the fuel system over for leaks but have found none. I have replaced the spark plugs recently as well. (It was doing this on the old plugs too). Could it be the timing set incorrectly :?:
Next tank of petrol i will go back to premium unleaded and see if the problem dissapears again.
Any help would be appreciated.
Kevin.
Kevin.
