I going to swapp the compressor house because what i read, the T3 compressor house is smaller than the TO4B on a s14/15.
http://www.sr20forum.com/forced-ind...7-rare-t04b-compressor-housing-gti-r-t28.html
^ is a link on the SR20from sight.
and also
OEM:
S13 SR20DET: T-25, 60 trim 56mm BCI-1 compressor, 53.8mm 62 trim
T-25 turbine, .64 A/R turbine housing. Journal
bearings.
S14 SR20DET: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing,
62 trim 53.8mm T-25 turbine. .64 A/R turbine housing.
Ball bearing center section.
S15 SR20DET: Same as S14, but with Inco turbine wheel (instead of
GMR), cast divider wall between turbine discharge and
wastegate.
Pulsar GTi-R: T-28, 60 trim 60 mm BCI-1 compressor in standard T-3
housing. 79 trim 53.8mm Inco T-250 turbine wheel .86
A/R turbine housing. Journal bearings.
quote from some guy.."GTi-R T-28 is a really good turbo. I think that it is better if you lose
the T-3 compressor housing and get a housing off of the S14. This is a big
improvement. With the T-04B compressor housing, the GTi-R turbo can support
about 16 psi and 280+ wheel hp. Makes pretty good boost by 3500 RPM, too."
So the hot 86 A/R on the GTIR is bad ass compared to is other SR cousins. Its the compressor housing on the gtir turbo that smaller. And by swapping the housing , it can breath better. I found a S15 turbo for very cheep + i have my spare GTIR turbo. So im going to give it a go.
