Hi all ref my last posting of car no power not running well under throttle have since checked fault codes and has come through clear any other ideas???????????????????
It ticks over ok but when power applied goes to s#=t...iwill try injector cleaner..is there a fuel metering unit on my car if so where is it.???????
please help.
is ur oil pressure ok???
check ur boost lines....
any smoke out of the back???
does it say its acheiving boost???
Is ur MAF sensor connected properly???
Blocked fuel filter???
Engine timing???
---and it may seem obvious but check u have a good earth!!!
wot revs is it going tits up on??? can u give a bit more info?
