GTIR Ownership and Modifications
I am looking to get a GTIR over the next couple of months. i first found out about them after a next door neighbogh owned one about 4 years ago and it was mapped to around 390bhp. I used to own a s14a that i built for grip and time attack but due to family commitments i had to sell. I had that mapped to around 340bhp and was pretty much a bare shell (got rid of over 150kg from the car)
I want to get back into nissans but not to sure whether to go down the route of the s14 (as i have previous experience) or go for a GTIR. I have heard horror stories about GTIR gearboxes which is the only worrying issue for me. So a couple of questions
- How light can you make a GTIR.
- Is there stage power mods like there is with the s14a SR20DET e.g. stage 1, stage 2, stage 3 etc and if so what are they
- How much power can be made reliably without internal work
- What is the handling like in these, is there enough adjustable after market suspension components so that the car can be set up properly.
- i know this is a very vague question but what is the average price for a decent condition unmolested GTIR. I have seen some recently on gumtree with bad paintwork but going for around £1600 and that seems cheap, on the other hand I've seen high powered GTIR going for around 4k mark on here.
thanks
The Doc
Joe, gearboxes on a 25 year old 4 wheel drive car can be hit or miss if you get a good one they can handle 400hp if you get an abused one they can fail at stock power and no amount of shotpeen, micro polishing ,cryo treatment will cure the fact if it's weak from abuse...the only way to see issues in gears is x-Ray and magna flux crack testing...if you can get a quaife (circa 2k second hand) then your fine for track use (providing your not a ham fisted moron) for upto and beyond 500hp as has been proven many times, again any dog engagement gearbox will be fine as long as you know how to drive ( dog gearboxes fail from not being able to change gear properly and generally being a poor driver as they have better and faster gear change ability and stronger engagement dogs and less parts to fail or wear out),
engine wise a good standard engine with a good oil cooler and good coolent system will handle 400hp and is much the same as the s14 sr20det but stronger in certain areas, and if you want to run more power they need very little to be able to do so internally (I.e pistons,steel mls headgasket, arp rod bolts)
weight wise you you should be able to get the car down to 1080-1100kg by stripping the car out and fitting Perspex windows etc...to go further there are members on here who have or produce carbon and fibreglass parts in which you can take a further 60kg just by changing the doors ,
handling wise, if you can read and use some tools you can do a lot of modifications to make the car castor and camber adjustable, as well as adjustable wheel base, track width and more, there are two members on here that have really worked this out and can supply you with good base settings and a how too on that. People have used and still do use the gtir in competition and it still holds the production car record on a fair few hill climbs and abroad is used extensively and wins ...
so all in all it depends on what you want to do, I would start with a car that is known and proven to be good and have a few sensible things then expand from there, be careful who you buy from as there has been many shady traders and people over the years and if your unsure about a car then get someone to have a look who knows what they are looking at.
vpulsar
As above and check for rust, there is a few rebuilt threads on here where you could learn the areas to look at more closely.
I had a quaife box in my old car for over ten years and went through many changes over the years going from 300 bhp to over 500 bhp and never had any issues with it at all, I've bought a quaife box again for my new car but this time with the added safeguard of a gearbox brace as well, If set up well they handle very well especially if you fit a front LSD.
Good luck!
great thanks for the information.
ok so its hit and miss with the gearboxes. Is there normally a common fault or can it just be different bits that go wrong. I guess as you upgrade one part of the geardtrain it will just move the strain onto another weak area.
its good to know the engines can take 350bhp without the need to forge.
Yer my aim is to get a car that has electronic boost controller, FMIC, intake, exhaust, coilovers and few other little bits and build it from there. they are just so bloody rare its hard to find a good example that stays for sale for a while.
thanks for all the information.
Mad
hi Joe,
fusion are experts with Gtir's and have some interesting facts here -
Fusion Motorsport - Pulsar GTi-R
350bhp in a gtir is vey decent as the cars are quite light anyway
I'm not sure that the reputation of the gearbox is really deserved. - They don't seem any more fragile than newer cars when used without mechanical sympathy.
I was talking to someone with one of those "special" Clios (I can't remember which one) and he has been through four or five boxes... but they're all off eBay so who know what state they were in.
I suggested a Quaife or similar gearset, but cheap was more appealing (and he's got the hang of changing them now).
I've never had a particular problem with mine. - The synchro on 5th isn't great, but Danny suggested that probably meant the box had been filled with the wrong grade of oil at some point. Having said that, mine is normally driven on the road with the odd bit of spirited driving.
So, yeah; hit and miss given that you don't know how the previous owner(s) treated it.
I don't think there's much else that goes wrong; clutches need to be replaced when the power goes up. On the basis that I don't see many threads about it, there aren't any common problems with the differentials or the drive shafts. Wishbones bend when you hit something hard.
nickr
I do like my gtir a lot but if its meant for track duty I'd always pick the one with the most aftermarket support and only two driven wheels. For a track car I'd pick an s13 and build that up. Just my opinion
shroom
Yeah if you like drifting lol but as you said a lot of support and following
nickr
Haha I guess I should clarify.. If the choice was s13 or gtir. For similar money I'd do a miata with k24 swap personally
You'll only get around 30-40kg off by changing the doors. Standard ones vary on whether they have a side impact bar (5kg more) or not, but they're roughly 20-25kg ish as a bare door. A lightweight one is about 5-6kg bare. Bonnet can save you 10-12kg at most and tailgate maybe another 7 or 8 I think if you included a plastic rear screen. 1060kg is a reasonable weight doing the sensible lightweight stuff. If you want to go stupid - cutting metal out , ripping dashboards out etc you can go lower.
