gt3071r
adi_gtir
id really like one of these for my car but i keep hearing diff stories, ill be runnin built motor and apexi power fc
will it more or less fit straight on, do i need manifold downpipe etc
wheres the cheapest place i can get 1 from (quite important)
do i need an external wastegate , does it come with an internal wastegate
also wen u was havin a apexi power fc mapped wud u rather get hiteq in wigan to do it or norris designs
ta
Trondelond
it's "more or less" bolt-on, and you can use the OE manifold. Oil and water need to be redone at least afaik. The elbow/downpipe will have to be redone. Besides, not much point in running a 3071 if you're going to choke it with the OE elbow. ;)
You can get the 3071 with both internal and external wastegate. You'll probably need an uprated actuator (and bracket) as well.
This should be useful : http://www.gtiroc.com/forums/search.php
Aaaand.. : http://www.atpturbo.com/
The page doesn't seem to be working right now, but it should be ok soon I suspect.
HotSnot92
Southeren Ireland Regional Rep
get clive at rc developments to map ur car set mine at 1.5 bar 1 year ago and its still flying :-D :-D
adi_gtir
my mates just had his subaru mapped at andy forrests its pretty flawless, he had his evo 8 done at rc last year not in same league
