gt28rs icw gizzmo chip
$ven
Hello people!
Just a question:
My car is now completely rebuild, after driving the first 150km,
the turbo-seals went bang, and massive amounts of oil where leaking
out of the DV.
Now: I'm running a gizzmo stage 2 chip (fuelling capable of handling 1.2bar) with 550cc injectors.
Will it cause problems when I replace my original tubby with a GT28RS disco thingy? (fuel maps maybe not adequate?)
Or will it be better to rebuild my standard tubby with a 360 thrust?
Don't really want to use something like S-AFC cause, because nobody can map it here properly...
opinions?
str_motorsport
hi mate, i think it should be ok with the gizzmo chip.
anyway, control the fuelling and a\f ratio with a wideband sensor to be sure.
Should be fine as long as u dont max out the afm. And check your air/fuel ratios as u turn up the boost.
Also an adjustable fuel pressure regulator might help if u do need a little extra fuel.
