H
hum
I have installed the above boost controller. When you first install it, it says to do a learning run. I set the boost controller at 1 bar, and set of at 10 mph in 3rd gear, it goes all the way up to 1 bar, but then the boost controller is suppose to start flashing then you do it again to confirm, but the controller is not flashing (by what I mean by flashing is the sign in the corner is not flashing), but if I set off in 1st or second it only goes to standard boost. And if I am at high revs (over 3000) in 3rd it also only goes to standard boost
So then I tried it in manual mode, and it did not matter what gain I gave it, it would only go to standard boost in 1st and 2nd gear, but if I start of slow it would reach a higher boost (depending on what gain I had put).
Can you help me?
My car is a Nissan pulsar gtir and it is completely standard.
Thanks
Ryan
Can you help me?
Thanks
Ryan
