Got a problem????
My pulsar has Neva done this before? Can anybody please help? Why has my battery light come on wen I'm driving it stays on??
GTIR1000
did you leave any lights on over night in car whaich has drained battery at all. Could be a fuse i dont htink it will be that serious. try charging your battery over night
Sunny-D
My girlfriends saxo did the same, the crank pulley had separated from the rubber dampener. If not its probably the alternator.
GTI-R Nath
try tightening the alternator belt, if that doesn't work take the car to a garage to get the alternator voltage checked.
It's the beginning of the end... almost certainly the alternator is about to die. Happened to me, and I had to get a ride home in the cab of a tilt-tray truck.
Cheers lads I sorted the problem the belt had started to perish around the outside of the belt and it slipped off the pulley!!
