Heres my quandry.
I had a problem a couple of weeks back with a leak at my turbo/intercooler flange.The intercooler pipe was damaged and leaking out air.This was causing the car to run rich,but only on cylinder 3 and 4.The plugs were black.I then welded the IC pipe etc and got it sorted.I cleaned the plugs and re-gapped them.They were only slightly out by 0.05mm.I took the car for a wee test and it went great.
Tonight on the way to our weekly meet I noticed it wasn´t charging more than 1.15 bar whenit should have charged 1.3.It then started missing both under boost but mostly off.I decided to drive home to check it.On the way home the "check engine" light came on.When I got home and restarted it the light had gone out and there showed nothing when I did the paperclip test.I took out the plugs and all 4 were black as coal.
Any thoughts or ideas? I think the plugs are gone and not properly ignitiing the fuel but Im probably way out there.What should I check/replace/do?:?
