gearstick
nismo-400R
hi guys,my gear stick seems abit loose as if its got play in it ive sat in another pulsar and mine feels alot more lose,any ideas what it could be?
Bush on the gearbox end of the linkage? I replaced mine and it took alot of the slack out.
nismo-400R said:
cheers fastguy,how hard to fit?long job?
Its a very easy job fella, As long as you have a good jack and axle stands ;-) , Their are two 12 mm maybe 14mm I can't remember bolts that hold it on and then another bolt to get the arm off so you can change the bush....
Just get underneath and take 5 min's to work out what you need to do, Whole job shouldn't take you more than an hour at most.....
