gearlinkage
S-GTI-R
hi,the gear linkage in my r has got play in it,is there a bush in the linkage sumwhere thats worn?any1 know wot its called and how much?its like when ur sat in it and move the gearnob its qiute free like play in it
I have a similar problem with mine, there's a spring on the bottom of the gearstick that gives it its springiness, check that hasn't come off. Failing that it could be the plastic ball thing is worn, I believe that's a common problem and think that's what's wrong with mine.
gtir bean
mine is like this.you can pull it up and down slightly.it also vibrates loudly at high rpm when you give it some beans.
