Thunder God said:
If it's the two I'm thinking of, You need to unbolt and pull out the speedo drive ;-) , Then you will be able to get at both easerly ;-) ....
you can leave it where it is but its a reet pain in the @rse if you do, you have to start pulling the transfer box away from the box so the bolt doesn't wind onto the speedo drive.
when removing the speedo drive it maybe abit stubborn, its only 1 bolt that hold it down, be real careful not to snap off the bracket that attaches it, i think the last 2 i've done have broken :sad:
i stil think my first answer was more than sufficient
