gordo
does the pulsar come with a gearbox oil cooler as standard? if not is it possible to fit one?
thanks
thanks
As you have thought some about box protection Rob do you know what the relative Box oil temps are getting up to?Odin said:Why would you need to blank off the gearbox breather :? , Their wont be anymore oil in the box at any one time, The vent will still need to be their doing the job it was designed to do .
Yes I see were you are coming from!Odin said:No mate I've haven't probed it as yet, I do intend to fit an oil temp sender in one of the lines when I get around to installing the system, But I doubt weather a cooler is really necessary for a daily driver, The only reason I had the box fitted with the fittings was because the box was being rebuilt at the time, And my intention to do a lot of track days once I've finally finished my shed.
If the oil temps do get to high it wont do the box much good, So it's more of a preemptive strike you might say.
Yes I suppose the top may be a little further from the outlet and thus will allow oil to "Pick up" more heat.Odin said:He only talked about it because I'd already done it and told him about it :doh: :roll: , I think the oil is best put back in the box from the top.
Whats the story on this has RC ever managed to tune it yet seams a long time now Rishi?RishiGTiR said:Mine is also all plumbed ready for an oil cooler.. I believe my AEM ECU can control all this..
and yes, Rob gave me the idea!
jpward said:Whats the story on this has RC ever managed to tune it yet seams a long time now Rishi?
Also what type of sensor would you use to get reading AEM coolant work?
