So the guy who bought it is trying to offload it on you?
When you say it wouldn't idle properly, what do you mean? They have a pretty lumpy idle naturally, but something as tuned as that will have a few tricks. - I've got HKS cams and no PCV... so on starting my idle normally goes ~1200rpm... ~600rpm... ~950rpm. It doesn't cut out though.
What happens if you give it a squirt of fuel;does it settle-down then?
Is it running a PowerFC (I can't remember) because they require a bit of fiddling to get the idle to work nicely... something to do with the closed-loop using the lambda sensor; it confuses it, and it works better without it?
A fault code check might tell you what's going on. Could be the knock sensor has gone... or it could be that this chap has flogged the crap out of it since he's had it, and now it's let go.
If you're seriously interested in it, try and convince a local member to have a look and tell you what they think.
