Smo
It's breaking my heart to do this as I love the car very much but unfortunately due to a baby on the way, the Mrs and I have decided that perhaps the Pulsar isn't ideal for our current situation. For this reason I am gauging interest in my R. I don't want to sell it and will keep it should the asking price not be met.
Additional information on the car can be found in the 'Members R' section.
The car was built and mapped by Perfect Touch and achieved 395bhp and 411ft/lbs at 1.7bar boost on a Garrett GT28RS turbo. I have receipts for over £17,000 spent on the engine including turbo & ECU (excluding new gearbox), and over £24,000 in total.
Engine/Power/Drive
- Tomei SR22 Full-Counter Crank
- Tomei SR22 Forged Piston Kit
- Tomei Forged H-Beam Conrods
- Tomei SR20 Procam (272)
- Tomei SR20 Cam Gear
- Tomei SR20 Pulleys
- Tomei Titanium Top Rings
- Tomei SR20 Double Valve Springs
- Tomei Retainers
- Tomei Lifters
- Tomei Spring Sheets
- Tomei SR20 Solid Pivots
- Tomei SR20 Shims
- Tomei SR20 Valve Guides
- Tomei Head Studs
- Tomei Main Studs
- Tomei Rod Studs
- Tomei Rocker Stopper Kit
- RB26 ACL Big End Bearings
- RB26 ACL Main Bearings
- RB26 ACL Thrust Bearings
- Uprated Flywheel
- Uprated Flywheel Bolts
- Cometic Headgasket
- Head Port
- Head Polish
- Head Skim
- Head Gasflowed
- Inlet Port
- Inlet Polish
- Exhaust Manifold Port
- Exhaust Manifold Polish
- 1mm Oversize Inlet Valves
- 1mm Oversize Exhaust Valves
- 3-Way Cut Valve Seats
- Acid Dip Block
- Deck Block
- Polish & Re-Hone Bores
- Blueprint Bottom End
- Balance Bottom End
- New Gearbox
- Uprated Selector Fork
- Complete Gasket Set
- New Water Pump
- New Oil Pump
- New Timing Chain
- Uprated Pressure Plate
- AP Twin-Paddle Clutch
- B&M Short Shifter
- 4x NGK Iridium BCR8ES Plugs
- 550cc Injectors
- Garrett GT28RS Turbo
- Forge Front-Mounted Intercooler
- Bailey Oil-Catch Can
- Pro-Alloy Radiator
- Turbosmart BOV (Recirc Disconnected)
- Z32 AFM
- APEX'i Power Intake Filter
- Mongoose Turbo-Back Exhaust (5" Tail)
- 3" Decat
Management/Diagnostic/Security
- APEX'i Power FC Pro (Inc. Commander)
- APEX'i AVCR
- APEX'i EL2 2bar Boost Gauge
- GReddy Turbo Timer
- Clifford Full Closure Alarm (Proximity Inc.)
- Locking Wheel Nuts
Handling/Suspension/Wheels
- Lowered 20mm (Springs)
- Rear Suspension Strut Kit
- New Front Shocks
- Front Strut Brace
- GAB Adjustable Rear Strut Brace
- Recent 4-Wheel Alignment
- League 111 Bandit LR-01R 16" Alloys (~6kg)
- Wilwood 4-Pot Front Brake Conversion (310mm Discs)
- Yellow Stuff Pads
Interior/Exterior
- Battery Relocated (Boot)
- Stripped
- Lockwood White Dials (not fitted)
- Sound Deadening Removed
- Momo Steering Wheel
- Alloy Pedals
- De-Tango'd Front Lights
- De-Tango'd Rear Lights
- Clear Side Repeaters
- Blue Samco Silicone Hose Kit
- Stainless Fusebox Covers
- Stainless Expansion Bottle
- Auto-Folding Mirrors
The spec list is all accounted for - I will leave the receipts to talk for themselves. She still reads in KMs and the clocks are showing 168,000 however the engine rebuild is considerably younger (completed at 138,412km) having covered roughly 19,000 miles. The oil and filter are changed regularly with the last 5 as follows;
2/10/08 @ 159,716km
2/11/08 @ 160,450km
18/3/09 @ 163,696km
28/7/09 @ 166,581km
16/9/09 @ 168,132km (including rear diff, gearbox and transfer box due to uprated selector fork fitment)
I have OpieOils receipts to prove the above oil changes.
MOT - December 11th 2009
Tax - February 2010
The bodywork is not perfect by any means - there are some small rust scabs on the car and some small dings/stone chips here and there. However the car is solid.
I am interested in part exchanging for either an Evo VIII FQ300 (Black or White) UK car or Tommi Makinen Evo VI (White) running circa 380-400bhp with cash your way.
Two short videos of the car can be found below;
Blowing Smoke Rings
Launch Control
For a cash sale I am after £6,000. I will not sell it for less.
Engine/Power/Drive
- Tomei Retainers
- Tomei Lifters
- Tomei SR20 Shims
- Tomei Head Studs
- Tomei Main Studs
- Tomei Rod Studs
- Uprated Flywheel
- Head Port
- Head Polish
- Head Skim
- Head Gasflowed
- Inlet Port
- Inlet Polish
- Acid Dip Block
- Deck Block
- New Gearbox
- New Water Pump
- New Oil Pump
- New Timing Chain
- B&M Short Shifter
- 550cc Injectors
- Z32 AFM
- 3" Decat
- APEX'i AVCR
- New Front Shocks
- Front Strut Brace
- Yellow Stuff Pads
Interior/Exterior
- Stripped
- Alloy Pedals
2/10/08 @ 159,716km
2/11/08 @ 160,450km
18/3/09 @ 163,696km
28/7/09 @ 166,581km
Tax - February 2010
Blowing Smoke Rings
Launch Control
