G Sensor?
D
dyobls
Hi All.
I'm having a problem with my ABS light coming on.
I have checked the "Blink Code" on the ABS ECU box.
It is giving 11 pulses which indicates there is a problem with the "G Sensor"
Can anybody help and let me know where this "G Sensor" is located on the Pulsar?
Also what does it do? Is it a form of tilt switch?
Hope you can help.
dyobls
The picture in the manual isn't very clear as to where it is :? It could be behind the dash somewhere or by the handbrake somewhere. Check by the hand brake first as that's nearer the centre of the car.
Maybe someone else knows exactly where it is.
if you can suffer it for abit i'll have one available soon as i still need to rip out the abs ecu and associated bits from inside the car
