FULL-RACE MANIFOLD
cmng
Full race manifold look great
but to fit on RNN14 you all better have a check carefully
since i afraid the clearance issue
since as i know RNN14 Engine bay is shorter about 10mm ( 1 cm )
stugtir
i was thinking about goin for the topmount manifold and getting a custom rad made up to sit to one side, i guess if it was a thicker enough core and had the right air supply it should be fine :?
i think using this manifold will save all that hassle we have with that pathetic dump pipe setup! as it sets the turbo slightly off towards the near side of the car a 3'' or 4'' downnpipe shouldnt be a problem at all :p
stu
its not that much bother, discodave managed it ok, si (00sid) uses it aswell, think muppet posted up how he did it...
do not fear the search function :wink:
zia
Posted: 22 Apr 2005 21:11 Post subject: FULL-RACE MANIFOLD
has any one used one of these before? they list a stock position manifold and also a top mount manifold! There a bit pricey but this is the only manifold that ive ever seen that looks like its good quality
take a look .
top mount:
http://www.full-race.com/catalog/product_info.php?products_id=50
the turbine is facing the wrong way! and you,d have check that once turned around that the compressor housing doesn,t hit the block/rocker cover.
stock position:
http://www.full-race.com/catalog/product_info.php?products_id=482
this one look's better and may even fit if the turbo doesn,t hit the rad
zia
stugtir
take a look .
top mount:
stock position:
zia
i didnt even notice that!! :roll: doh!!
the stock position one looks like the way to go then. ive emailed them so ill let u guys know what the deal is with the awd stock position manifold.
stu
nismoboy
take a look .
top mount:
stock position:
zia
stu
we want pics of it fitted to a pulsar using the original dumpipe to confirm it does fit in the stock location. i want a tubular manifold bit it has to fit in the stock location because i have a rather expensive frontpipe/dumpipe and i dont want to have to change that again.
antilag
nice to see u boys are still turning easy modifying into difficult fabrication (i no what im trying to say even if no one else does) lol jeex just buy theses parts and fit them were talking hoiusrs labour to modify whats the drama???????? do tell....
Allan GTI-R
i'd buy one of these in a second except a GT3071 will not fit as it's too close against the block :oops:
