Here's a thought to chuck about for a bit
In the pic below (ignore the engine, this was lifted from the GTR site, it's a scooby being prepared by Prodrive) look at the top front suspension turrets and lack of "bolt on" adjustable top mounts and strut brace. No bolt on bits here, the strut bracing is taken care of by welded the bracing permenantly into position and the adjustable top mounts are actually part of the top of the turret.
Now obviously on the N14 shell the strut bracing can't be welded into position in the same way but if the exposed part of the front suspension turrets were renforced then steel bacing could be welded into postion in a similar position to the bolt on alloy ones available for the N14.
Then if the turret tops were reenforced anyway, could we not encorperate a similar adjustable/slotted plate so that some camber/caster adjustment could be made to a standard type strut top.
Thoughts ?
Heres an attachment for you phil
Thoughts ?
