C
Chi-town
i know i read a recent post about this but i cant find this...after fitting a FMIC the oil cooling line is rubbing on the FMIC how do i prevent this chaffing through the oil line?
:lol: :lol: :lol:Uncle Winnet said:move it
Yup, thats what I did and have had no problems in 4 years.some crazy people just remove it all together
iv had no problemsJIMMYBACK said:some crazy people just remove it all together :shock:
How about "UGGA BUGGA" :lol:deisel weasel said::lol: :lol: :lol:Uncle Winnet said:move it
i wish i got there first with that one 8)
Or use one of the rubber coupling pipes to join the two endsstevepudney said:Yup, thats what I did and have had no problems in 4 years.some crazy people just remove it all together
If you follow the power steering pipes from the reservoir they go straight out towards the drivers side headlight if you remove the headlight you will see the pipes are joined by rubber coupling pipes, all I did was remove the cooler (the whole front section) from these couplings and fit a 6" section of silicon pipe and two small jubilee clips too join the two ends together, hey presto, job done
Tried that and the OEM pipe is really a little to short and it kinks over time. I only used a longer section of silicon as it's less likely to kink or split than a 12 year old piece of rubber.Chris G said:Or use one of the rubber coupling pipes to join the two endsstevepudney said:Yup, thats what I did and have had no problems in 4 years.some crazy people just remove it all together
