you can see the fill plug on through the drivers side front wheel arch. There's a hole through the side. Look at the transfer case for a plug with a 3/8 or 1/2" drive in it.
BTW, how in the world did you crack your transfer case drain plug? Mine was dang tight. Still not off.
Hey Odin, we changed the transmission oil seperate from the front diff. Is there any contamination from the old oil from the diff to the new redline in the transmission?
And since the transmission is full of good oil, can I drain the transfer case and none of the redline from the transmission will come out?
