found these
D
danmo
prob best getting a better known brand that can be trusted to be accurate. not worth the risk imo.
AJ4
PLX are one of the best brand of wideband lambda kits you can buy.
I'm glad i didnt go out and buy a wideband air/fuel ratio meter before i saw that, that does a hell of a lot more on top of monitoring air/fuel ratio 8)
I like the sound of this too:
Built-in amplifier for audible knock output to speakers or headphones
Would that work ok from the standard knock sensor fitted to the car though?
CruiseGTi-R
I've had an R500 for a couple of months now. Brilliant. Does soooo much.
However, it doesn't work with our flat type knock sensors. You can hear knock (can use headphones straight out the unit) but the unit can't detect the voltage. Its a small loss though.
