skiddusmarkus
Those who have a forge fmic will notice you cannot refit your tow eye in the original place as the samco pipes are now in the way.Now I've not needed to use it since I fitted this many years ago but as the car is now on coilovers its too low to use the thick steel tube that runs under the engine between the wings for strapping down to a RR etc.
I've had a good look at the eye and I reckon if I cut it in half along the U shaped part of the bend in the steel that gives it its 90 degree angle L shape I can bolt it on using 2 bolts and rotating it from horizontal to vertical as the 2 bolt holes on the remaining part of the eye are a good match for whats already on the chassis.
Has anyone else done this?How have others with the forge fmic got their towing eyes back on?
