flywheel?
steven_c
are the fly wheels marked or balanced? removed one and dont know if i should of marked it!!!! will it matter what postion i put it back on in?
stevepudney
GTiROC CHAIRMAN
You'll be fine....
You should have really marked it as the whole rotating assembly (crank, rods, pistons, crank pulley and flywheel) will be balanced from the factory but the whole assemblie's balance will be thrown off the first time the clutch cover is replaced anyway...... But in theory, if the flywheel is just put back on and torqed back up it should be OK. You will be very unlucky if you notice any difference in the way the car drives/engine rev's.
Steve
steven_c
the engine never came with a flywheel on so hence could'nt mark, the flywheel i have got is lightened and balanced.. so should be all good cheers
