do flamer kits work any good on gti-r
Yep, using the Maplin kit. I use a 555 timer circuit, set to simulate about 4k rpm from memory. I've found on ones I've built that do work, the timer works fine and there's no need to use any varible rpm switching.FAO J-Gti-R,
I gather you are using the Maplin Ignition kit, are you using a seperate timer circuit like a 555 or something ?, or are you just taking the signal from the ignition amp ?
Have got a built Maplin module, just wondering what is better, a fixed 555 timer or a variable rpm based frequency.
Ross.
The big flame out the back works just like the space shuttles booster rockets and propels you forward at a terrific rate of knots for approximately 0.0000001 of a sec, happens so fast that ordinarily you wouldn't see it, but through time and motion capture technology i have witnessed this awsome burst of speed on a Morris Ital with twin turbo and flamer conversion :roll: :lol:Sirnixalot said:some one want to explain to me why this is a "performance" mod and not a styling mod?
