Fitting new speedo cluster... need advice...
Jim_1979
Ok, I'll possibly be fitting a new speedo cluster to the car. I don't think the new speedo has the ABS light on it or not. Not sure....
As you can see you can't see the writing, but it does have the bit still. Saying that it doesn't have the indicator arrows either?!?....
Does this mean it doesn't have the ABS light? If it doesn't will they still fit and work fine?
Thanks for the help in advance!!
jpward
the abs and indicator bit is only a piece of plastic infront of the bulbs!
Id say the owener of those clocks removed the ABS and to pass MOT removed the bulb and the antilock card so as to say it has no abs otherwise it would fail any sunny cluster will have this bit you need ;-)
Jim_1979
Because I don't have them yet.
It's all good tho... going to get a set from Kirko... :)
Kirko... you have pm.
