fitting crane hi-6
GTIR-LOZ
hi just got this delivered today and need a bit of advice to set it up,
1)which wire do you use for the cylinder select wire it says a thin switch 12v, is that just an ignition supply
2) can you remove the old ignition amplifier etc after fitting or do you leave it still connected (and is it the thing below the coil)
3)where do people put their amplifiers as its chuffing massive and i still have the battery in the stock position
think thats it
thanks
