fitting catch tank
williams
is it k to run the breather from the top left of rocker cover and 1 from the right of rocker to a catch tank?
i have also removed the black canister from front of rocker and just ran a hose in its place.
this ok?
Let me get this straight: you've taken the PCV out and want to connect it to a catch can... and also the other breather? You've also taken-out the oil/mist seperator and replaced it with a pipe?
If that's what you want to do, there isn't really a problem with it. I'd probably attach the drain from your catch can to the sump (so that you can empty the oil back into it) by that hose, and vent the top to the air.
