gotoinstant-redline
hey all,
just got my new gearbox all fitted and sorted. the car purs like a kitten now and its ready for a rip up the road..
its taken me about a week to swap the box and do a whole load of other jobs to my car. first time i've ever done any real work on the R.
problem is that just as i'm warming up the car ready for the first test drive, the turbo starts to smoke!!!!! NOOO!!!
there is no smoke out the exhaust and the exhaust gasses dont smell of oil. the engine is brand new and still 200miles shy of being run in. the turbo was in perfect health last time i used the car.
thing is now there is oil leaking from somwhere on the middle of the turbo and spraying oil onto the hot side of the turbo. then the heat burns the oil and i get a cloud of smoke from the front of the car.
i'm guessing that its the oil feed to the turbo that has sprung a leak.
i've been on the floor looking up, on the top looking down and using mirrors etc to see where the oil is coming from. i cant track it down at all.
it must be right behind the turbo next to the block.. is this where the oil inlet to the turbo is?
its a small amount of oil, like form a pin hole sized leak. but on the hot turbo it burns fast
i've not driven on boost (or at all yet) to see if the exhaust smokes etc.
the oil only leaks when i rev the car.
oil presure at idle is over 4 on the dial and it drops to just above the next line down when up to 80oC. when i rev the car the presure goes back up over 4 again (not reving more than 3900rpm due to run in.) and takes a while to come back down.. a 4 or 5 secs i spose.
is my turbo shot?
should i drive it and see if the exhaust smokes?
is it just the oil feed?
is the oil feed behind the turbo in a hard to get to place?
do i have to take the manifold off to repair it?
how much are SS braided oil and water lines?
if oil is leaking then should i not drive on boost for fear of starving the turbo of oil?
gah bloody cars! you fix one expensive problem and you get another!! grrr
cheers
Luke.
is my turbo shot?
cheers
Luke.
