S-GTI-R
does the pulsar need a fuel cut defencer 2 go ova 1.2bar?
u sure rishi as mine was running 1.4 bar boost and had nothing else on the r apart from the 3 wire boost controller thats all off 2 pound to make on it :lol: :lol:RishiGTiR said:Yes there is a Fuel Cut... It should cut at just over 1.2bar...
Using an aftermarket ECU, Piggyback Controller all bypass/eliminates the Fuel Cut...
Rishi
JIMMYBACK said:u sure rishi as mine was running 1.4 bar boost and had nothing else on the r apart from the 3 wire boost controller thats all off 2 pound to make on it :lol: :lol:RishiGTiR said:Yes there is a Fuel Cut... It should cut at just over 1.2bar...
Rishi
yep i have one in my tool box that i took out of my carmattygti-r said:also HKS EUROPE list a Fuel Cut Defender for PULSAR
AJ4 said:If you look at the wiring diagram for the car, boost is only measured in one place, and thats only to drive the electronic boost guage. At no point does the signal get routed into the ecu or fuel control circuits. If the ecu doesn't know what boost the car is running, how can it tell when to cut fuel ?
We've had this argument dozens of times now, and still no-one has managed to point out which pin on the ECU is the boost sense line
It would... but it doesn'tRishiGTiR said:Well it could take its cut reading from the MAF Voltage and cut out at a certain voltage... That would work...
