Glenn
I recently serviced my R coz it was hesitating alot, as if running on 3 cylinders on and off....Eventually after changing the leads, plugs, filters, oil etc and cleaning up the Dizzy and Rotor, it started running fine. (i've since put new dizzy and rotor on as well). However, its now started running hesitantly when warm.....on most occasions, but not all!! When it does this, boost builds up slowly, and only to about 0.5 instead of 0.6-0.7 as normal.....and it feels like its having to work hard to get there..
I'm assuming a leak in the system would cause a prob all the time...
Been informed might be DET or coolant sensor. Where are these so i can check them out? Or any other ideas guys? The frustration is unbearable :x
