Fault Code 11
GTI-R Nath
got fault code 11 today, the crank angle sensor circuit fault, is this a big job to fix. not really even sure ware i would start with this one, so any help would be great.
GTI-R Nath
is it difficult to change the distributor and reset the ignition timing, or will i be better off just taking it to a garage to get done
GTIR1000
easy job to change the distributor mate its just on the side of the engine i did mine the other day change the rotor arm aswell. i havent dont the timing but im sire there is a how to guide on here :)
GTI-R Nath
yeah i no the distributor cap and rotor arm is easy job, but i am needing to change the Distributor not the Distributor cap
vss irvine
its an easy job as its only two bolts and only fits one way.
mark the position of the old dizzy before you remove it and put the new one on as close as you can.
it wont be exact but itll still run until you get the timing done.
