FAQ - Turbo - Nissan SR20DET, Garret T3/T4, HKS GT Series turbo info
Status
Not open for further replies.
Sirnixalot
Nissan/Garrett standard turbo information
S13 SR20DET: T-25, 60 trim 56mm BCI-1 compressor, 53.8mm 62 trim
T-25 turbine, .64 A/R turbine housing. Journal bearings.
S14 SR20DET: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing,
62 trim 53.8mm T-25 turbine. .64 A/R turbine housing. Ball bearing center section.
S15 SR20DET: T-28, 60 trim 60 mm BCI-1 compressor in T-04B housing with Inco turbine wheel, cast divider wall between turbine discharge and wastegate. Ball bearing center section.
Pulsar GTi-R: T-28, 60 trim 60 mm BCI-1 compressor in standard T-3 housing. 79 trim 53.8mm Inco T-250 turbine wheel .86 A/R turbine housing. Journal bearings.
HKS GT Series Turbo Info
GT2510: T-28, 63 trim 60 mm BCI-1 compressor in T-04B housing. 62 trim 53.8mm T-25 turbine. .64 A/R turbine housing. ball bearing center section.
GT2530: T-28, 63 trim 60 mm BCI-1 compressor in T-04B housing. 76 trim 53.8mm NS-111 turbine. .64 A/R turbine housing. Ball bearing center section.
GT2540: 46 trim 76.2mm BCI-8 compressor in T-04E housing. 76 trim. 53.8mm NS111 turbine. .64 A/R turbine housing. Ball bearing center section.
GT2835: I believe that the following is the spec for this, but I could bewrong: 48,52, or 56 trim 71mm BCI-18C compressor in T-04E housing. 84 or 90 trim UHP turbine cut down from 60mm to 56.5 mm. .64 or .86 A/R turbine housing. Ball bearing center section.
GT3037: 48,52, or 56 trim 76.2mm BCI-18C compressor in T-04E housing. 84 trim 60mm UHP turbine. .61, .73, .89, and 1.06 A/R turbine housing. Ball bearing center section.
Garrett T3/T04 turbo info
Super 60 T-3: This could be about anything, but is usually a 65 trim
60mm BCI-1 compressor wheel in either a standard T-3
or a T-04B compressor housing, with a 62 trim 58.x mm
T-3 turbine wheel in a .49 A/R turbine housing.
Stage 3 T3/T-04E hybrid turbo. 40-60 trim 76mm BCI-4 or BCI-8
compressor wheel in T-04E housing. 76 trim 65 mm T31
turbine in .49-.82 A/R housing.
Stage 5 T3/T-04E hybrid turbo. 40-60 trim 76mm BCI-4 or BCI-8
compressor wheel in T-04E housing. 76 trim 72 mm T350
turbine in .63 or .82 A/R housing.
gtirpulsar
Just to add the manufacturer quoted maximum expected power output of the HKS series
GT-SS 280PS
GT2510 300PS
GT2530 320PS
GT2535 340PS
GT2540 350PS
GT2540R 350PS
GT-RS 400PS
GT2835 380-410
GT2835PRO 420PS
GT2835PROS 420
GT2835R 420PS
GT3037PROS 480PS
GT3037 420-470PS
GT3037S 450-480
GT3040 500PS
GT3240 580PS
TO4S 550PS
TO4R 650PS
TO4RR 700PS
T51R KAI (BB) 800PS
T51R SPL (BB) 1000PS
Sirnixalot
not really...but they are really only suited for drag racing or top speed setups
What do recon on my new turbo then matey t04 r?
how laggy do you think it will be then?.
Sirnixalot
you gotta give me a little more info to work with rob :p. Do you have the Trim and A/R of the compressor and turbine on that thing? Its big though so as a rough guess...5750-6500rpm for full boost
ashills
mine is the top one and Vs is teh bottom (i think :)
JGYBB37 - TO4B Compressor housing with 56 trim GT35
compressor wheel. 44lbs/min air flow. .86 AR T2 exhaust
housing with 76 trim GT25 turbine wheel. Good for 400+HP
and bolts on to SR20DET manifolds and downpipes.
Internal Wastegate.
JGYBB37R - TO4B Compressor housing with 56 trim T04S
compressor wheel. 55lbs/min air flow. .86 AR T2 exhaust
housing with 84 trim GT30 turbine wheel.
Good for 500+HP and bolts on to SR20DET manifolds
and downpipes. Internal Wastegate.
Sirnixalot
Internal Wastegate.
Rob the turbo isnt a T04...its a large T-28, its just using the T04 compressor housing :wink:
Turbo #1 on that list will make boost around 3500-4000rpm.
Turbo #2...expect another 500-1000rpm of lag so look for boost around 4500-5000rpm.
These figures are conservative, you should make boost some where inbetween these numbers
cmng
JGYBB37
= Garret GT25=
CHRA Part no = 446179-0032
JGYBB37R
= Garret GT30=
CHRA Part no = 700177-0015
Thats pretty good then not to laggy mate 8) 8) :wink:
ashills
just means ill be gone V before u spool up :D
only kidding mate ill probably blow mine up by the time uve done urs lol
lol :wink:
With Motec launch control and anti-lag I don't think so matey :twisted:
GINGA
That better be full boost by 4500-5000rpm :?: otherwise the shares in nos will be going up lol :lol:
Guys in the gt hks series what are the PROS series.
eg
GT2835 380-410
GT2835PRO 420PS
GT2835PROS 420
GT2835R 420PS
GT3037PROS 480PS
GT3037 420-470PS
Muppet
GT-SS 280PS
GT2510 300PS
GT2530 320PS
GT2535 340PS
GT2540 350PS
GT2540R 350PS
GT-RS 400PS
GT2835 380-410
GT2835PRO 420PS
GT2835PROS 420
GT2835R 420PS
GT3037PROS 480PS
GT3037 420-470PS
GT3037S 450-480
GT3040 500PS
GT3240 580PS
TO4S 550PS
TO4R 650PS
TO4RR 700PS
T51R KAI (BB) 800PS
Not wanting to make myself look to stupid but what does PS mean.
thanks muppet.
memski
Cool so I have over 2700ps :D Time to kick some skyline ass at totb3 :p
nikko I know Ive asked you this before but could you post for the benifit of the guys on here what the trim and ar housings are and how they affect performance?
Also what would be useful if to list at what rpm each of the turbos on the list reach max boost
Status
