FAO anyone running a Mocal oil cooler..Q
jasegould
What size pipe and fittings do you use?? The plates use 1/2" fittings which seem a bit too small to me, would there be any benefit usuing larger diameter hose even with the 1/2" fittings??
Jay
Sirnixalot
is that 1/2" ID or OD (inside or outside diameter)
If its 1/2" ID you need to use 5/8 line
jasegould
I/D...I have used the part numbers supplied by someone else but they are 1/2 ID, will change to 5/8 ID
Thanks
Jay
Sirnixalot
i was thinking hose was measured by OD. Try to use the same ID. If you too larger a hose you will get a pressure loss.
