Fans
Boooooost
Ive got my new rad and fans fitted and need to wire them up I just wanted to know if both the standard fans are for cooling the rad or if one is used for the air con? If one is for the A/C which side is it?
Cheers Matt
jpward
Just use the cars original wiring! (remember polarity) :lol:
Both mine kick in together even when ac was on.
Boooooost
Hi thing is i've ditched the a/c and need to know if both fans will still run off the factory loom or if one was just for the a/c rad. On newer cars one fan is for a/c and the other coolant rad is the R the same?
Matt
jpward
ME 2 mate and yes they both run as before so always mind the pinkies when working at the engine bay with the ign on :lol:
although im in the middle off a sneeky plan to remotely switch the fans so to cut down on my heat soak!
