Fail MOT on . . .
ShayneG
Can you fail your MOT on the exhaust blowing :?:
coz Power$tation have told me mines blowing from the manifold as the gaskets gone and that the engines gotta come out to fix it :?
if so I'm buggered coz MOT's up today and I can't afford for the engine to come out just yet :shock:
Moved to Regular Servicing - FAST GUY
It could, but the mot manual does give a little leway if it's a small blow.
I don't think anyone has taken the engine out to fix the manifold gasket, have they? :shock:
ShayneG
I really can't see how the engines gotta come out but when a reputable company tells u so then what do u do :roll:
It is blowing rather loudly :(
You do exactly what you did, ask on here.
It'll fail then if it's loud.
E
Edd
as you live in redditch i might be interested in fixing it for you for some £££ :roll:
engine out my arse :evil:
E
Edd
and it should pass an MOT....if your sturggling my mate might be able to MOT it for you :shock:
C
Crazy
Same problem I have at the moment :(
I am sure that the engine does not have to come out :wink:
PowerStation changed mine about 4-5 months ago when they fitted my MD214 rollerbearing turbo and the engine did not have to come out :)
How much and when can you do mine mate :?: :?: :wink:
PLEASE :!:
K
KRS
Engine Out!!!
No way! It was the first job I ever did to my R, Theres one annoying bolt thats hard to get tight, but apart from that, If you can use a spanner, try it yourself!
I remove the radiator, fans & Turbo to intercooler pipes to get to the manifold easy.
T
Tart
Powerstation wouldn't take the lump out. My mates r had that and its a long job cause they take the turbo out but not the lump!!! did u hear them correctly??? He had his done at powerstation!!!!
cojack
There is no way in the world u have to take the engine out it is a doddle. and yes the car can fail a mot if exhurst is blowing only if shows up on the gas test :D
They can fail you for an excessive leak, it doesn't have to show up on the gas test as I have failed before on leaks from the manifold area and it passed the co test at the time :(
Mr GTiR
to take a manifold and turbo off the car should take no longer than 1 1/2hrs. If your good then 1 hour :wink:
Edd, over to you :p
Stevo
i had mine done with engine in car, just take rad out and u can get turbo out.
dont listen to them about engine out job its bollocks.
E
Edd
Edd, over to you :p
19 minutes is my record so far thankyou very much :wink: :lol:
and thanks for ringing me on saturday :roll: :roll:
purplemonster
i am an mot tester :)
and if it is a very small leak then it should pass ,if it affect emisions it will def fail
most exhast leaks will affect the emmsions in some way shap or form
