Expansion tank location with Hybrid FMIC
PaulB
hi guys,
im just don my front mount, and i know i have to move the washer bottle, but wot do i do with the expansion tank?? It has about a 3inch length of small hose into it and now wont go back in.
Aint seen it mentioned, so can any1 help me out?
cheers
On the Forge kit, they give you about a 1m length of samco, so you can relocate the exspansion tank next to the battery.
As seen HERE
another sunny
my hybrid fmic pipes alowed just enough room to rotate the bottle and squeeze it down against the relays, dont know how much room you have there? give it a try.
gtirx2
As above you can fit it between the relays and the hot pipe just turn the bottle 90 degrees and you should be able to squeeze it in.
