quote:Originally posted by nismoboy
Cos im interested in seeing the different companies designs.Ive currently got an hks front pipe,2 1/2 inch de-cat pipe and magnex middle and rear sections.I want the perfect exhaust with enough back pressure for bottom end torque but still free flowing enough to support a future 450bhp.The problem with my system is the hks front pipe is 2 1/2 inch bore at one end and 2 inch at the other which is restrictive as i need a full 2 1/2 inch system to get the power out.The other thing i dont really like is the back box as it has an S bend design which again is restrictive so thats why i would like to see some other designs and maybe change some things about.To start with i want a mongoose front pipe as they are 2 1/2 inch all the way through and they`re stainless aswell,then maybe keep the magnex middle section and try and find a decent back box.so come on guys lets see some pics cheers nis.
bit of a mish mash this.
you say you want a bit of back pressure for torque production low down.turbo motors do not like back pressure but,i do believe that simon norris has a little built in for his evo`s as he says they need a bit of back press for torque production.
you then say you want to get rid of the bend over the back axle as this causes a restriction.it is this restriction that will cause your desired back pressure.
what you need is a few pics of my system,i think skiddus has some,4" bore from turbo to back box and the box now exits in the middle of the bumper as it`s almost a straight run.
dp can make up s/s systems in a variety of diameters along with the back boxes which also come in a variety of internal diameters.these systems will not be cheap as they are totally bespoke and they will have little or no back pressure.
