D
		dan-dan
Hi my friend has got a gti-r, he recently had the engine out to do the clutch. once he refitted the engine it started up fine and drove ok for about 4 weeks, last night he had just left work and got about 2 miles away, when alls of a sudden the engine backfired, splutted and then stopped to which he couldnt get it restarted. i went over a little later on and took all the spark plugs out and found them all wet with petrol so we wiped them dry and tried to run it once again but still no go, so i removed the plugs again and found them all really wet so i decided to check the ignition side was sparking at the plugs which all four cylinders did. i left cylinder 4 spark plug out and tried to start the engine again and it started up and ran. i tried to refit the cylinder 4 spark plug after we had it running and then it wouldnt restart again and all plugs were wet again with fuel.
He said when he tried to get it to run before i came over it did a massive backfire and still wouldnt start. if we got hold of the throttle while turning the engine over it would sound like it was hydraulicing which seams a little weird. i think it could be something to do with the air flow meter telling the engine there is more air than there actually is.
Any help would be appriecated
