H
hijacker1
could sum1 plz tell me were the nut is to drain the engine oil or do i just have to take the oil filter off?not 2 sure. :?
PMSL... don't even joke about that shit, someone WILL do it, lol!!!geetee said:You can if you run the engine after removing the oil filter
NOOOO DON'T!!!
GeeTee 8)
What are you lot on about. I always run the engine after draining the oil. Then I fill the sump with sand to collect the last few drips of old oil. Run the engine some more, then put the new oil in.J-GTi-R said:PMSL... don't even joke about that s**t, someone WILL do it, lol!!!geetee said:You can if you run the engine after removing the oil filter
NOOOO DON'T!!!
GeeTee 8)
PMSL even more (please stop!! :lol: :lol: ).What are you lot on about. I always run the engine after draining the oil. Then I fill the sump with sand to collect the last few drips of old oil. Run the engine some more, then put the new oil in.
It doesn't take the engine long to grind up the sand then you're back in business
Oh I guess that gives a higher quality response what with ball bearings being better than sand.Edd said:I always heard that after you've drained your oil, you should put in a jam jar of ball bearings, run the engine for 10mins, drain excess content, refill with oil and then away you go :?:
