engine mount dimensions
ashills
has anyone gt a set of engine mounts they can measure for me to compare to some ply ones i have as i need to check them etc
cheers pics would be cool aswell if possible
ashills
i need the measurements of the dia. the pin posistion and thickness and which mount they are
andy i have two sets here but i think they are no better so ill check all dimensions myself before i send u another set of dufs lol
stevepudney
GTiROC CHAIRMAN
OK, I have a spare set of Nismo ones here, I'll measure up and post with a couple of pics tomorrow if I get the time.
stevepudney
GTiROC CHAIRMAN
Front G/Box : 73 mm ID (of the mount itself), Central M10 Pin & 40mm thick
Rear G/Box : 81 mm ID, Offset M10 Pin (See below) & 45mm thick
Top Drivers side : 81.mm ID, Central M10 Pin & 50 mm thick
Photo and Diagram displaying sizes of the rear G/Bix mount
ashills
nooooooooo they have cocked up again
theyve put the offset pin in the 73mm one instead of the the larger one
Mr GTiR
LMFAO, that's the second time they have done the same thing again :doh: :doh: :doh: :doh:
stevepudney
GTiROC CHAIRMAN
ashills said:
steve have u got the width of the sleeves please ae as they are important
Alan
What do you mean by the sleeves, the thinner steel band that encases the rubber mount or the bolt sleeve through the centre of the mount.
Steve
