to all those who have got a emanage blue or ultimate, jut wanted to see what you think of them, and what sort of power are you running?. they any good? good value for money?
Blue is good for near on 400bhp, ultimate is better but mainly due to its extra features. it can do more but that doesn't mean what the blue does is not good enough!
If its only a map to run higher boost you don't need to use the second map. However, if you change fuel octane then you can run a different ignition map, and if you run special or oxygenated fuels you can use the additional fuel and ignition map. It really depends on what you want. There are usually many ways to solve a need or problem with the emu.
