emanage blue
samgtir
Just ordered an emanage blue from www.mohdparts.com for £170 ish, i'm just wonderin if i need to order any extra harnesses or does what i need come in the box? does anyone know what comes with it???
Afaik buddy you need to order all the harnesses (ignition, injector and pressure (as well as pressure sensor)) as, you only get the 'brain' with the emanage blue. You'll also need the support tool ! If you go for the emanage ultimate, I think you get all the harnesses you need ?!
rayman75
im sure if you went for the ultimate you would've got the ingnition and injecter harness. would also suggest getting the pressure sensor aswell.
keggles2001
what does the e-manage actually do? (sorry to sound thick) is there any uk distributors or is it cheaper to have it imported?all info greatly appreciated
F
Fusion Ed
The e-manage is a piggy back fuel and ignition computer. It allows you to fit virtually any mod to your engine and modify the stock ecu response to inputs to take advantage of the new modifications.
