Mr GTiR
sorry to any mods but i need help on this!
i've just had the engine rebuilt and put back in.
Everything is connected but the f***ing thing won't start!!!
I've checked that the fuel pump is working as you can hear it start up and fuel is getting through.
I've so far swapped my coil, dizzy, HT leads, ignition amplifer, and ecu all off a car that is in good working order.
All the earth's and power sources have been checked and are fine. All the electrials plugs are in.
The car will crank over but just won't fire from the f***ing coil!! There is an electrical signal going to the coil but the dam thing won't spark!
I've had a mate down with Consult II and the only faults are:
Camshaft Posi Sen 0
Ign Signal Primary 0
I have been told as the coil is not sparking these faults will show up as the dizzy and crank sensor was off a good car at the time of the test!
On the coil there are two wires, one of which is a live and the other a switch live. I have been told that the live is a good 11.3V and also same for the switch live. However when i try to start the car the switch live is dropping to about 6/7V :? Now after trying all of the above parts we think it's the switch live that is at fault or the wiring harness. Anyone ever had a fault simular to this or can suggest somthing?
Also, i have noticed that my rear heated window demister does not work and the n/s front light (but indicator does work :? ). I don't know if this is connected or another problem i have.
Anyone know the wiring circuit on an R or offer any sugestions?? Really i need the help of an auto electrician but don't know/afford any.
help.....
Moved- Hannie (sorry but got to be done!)
Camshaft Posi Sen 0
help.....
