More than likly the window switch in the drivers door card its well known for failure. There was a guy offering a repair sevice for these switch units but i cant remember his name try doing a search it should turn somthing up.
do all of the rockers still work OK ? It was usualy the pins that broke and I have these but dont have a full replacement unit at the moment []
if not U have 2 options.
1 remove the switch from the door and check the connections R in ok and that the pins have power to them. If you R brave you can seperate the plastic surround and check the circuit bord for components that have come loose.
2 remove the unit and send it too me. Cannot promise a fix but can clean it (see if that fixes it) and look for any blown components as specified above.
Thanks for ur help mate. I had a look yesterday and it looks fine (to me!) I think i better send it to u to have a look. Can i have ur address and an estimate of the cost plz ??
Send it in a little box (with padding) & a cheque for £10 for return postage. I'll ring around local scrap yards and look for a replacement if u need it its wattever they charge £5-10 ish. OR check your local ones first. If you find one I can put them together to make 1 working one.
